Lifting hooks on NH7308 FEL
   / Lifting hooks on NH7308 FEL #1
LarryD
Whidbey Island, WA.
TC33D
I'm looking for ideas on welding a lifting hook on the top of my NH 7308 FEL. The rolled steel seems a bit thin for a direct weld and I don't want to pick any heavy loads from the side. I suppose I could have some 3/8" steel rolled to the same shape and reinforce the center of the bucket. Has anyone made this modification to their FEL?
   / Lifting hooks on NH7308 FEL #2
I bolted three heavy duty forged 'D' rings from Northern in the middle and near both ends of the flat portion of the upper bucket behind the rolled edge.
They were about $7 each (#150086) and I can use chain, rope, or straps off the front or back of the bucket. I used 3/8" bolts with large fender washers and the bucket has never tried to bend. Paint them or they will rust.
These were simple to mount and have worked very well for me.
Rip
   / Lifting hooks on NH7308 FEL #3
My dealer welds on a flat 'bridge' (1/4 thick, 5 inches wide, probably 10 inches long) that goes from the back of the bucket up onto the round part, then welds a hook onto it. it's very strong..
   / Lifting hooks on NH7308 FEL #4
Rip:
Can you post photos?
   / Lifting hooks on NH7308 FEL #5
The attached picture shows what I had welded to my 790's bucket. This should be good for the loader's lift capacity.
If it makes you feel better, weld the hooks to a ¼" plate about 4" x4" or so, then weld the plate(s) to your loader.
That will be quite adequate unless you plan on some really heavy lifting.
BTW, the bucket material is .125" thick steel.
   / Lifting hooks on NH7308 FEL #6
My hooks are partially mounted on 1/2"x 3" plate that is bent at a 90* angle to go down between the bucket mounts. Bucket Hooks
   / Lifting hooks on NH7308 FEL #7
I just used a hitch mount with a drawbar. You can change attachments with this and still be able to use it for trailers etc. I just add a Clevis to the drawbar to lift and pull things. So far this has worked well. /forums/images/graemlins/smirk.gif
Hope this helps.
   / Lifting hooks on NH7308 FEL #9
Hank
Good idea! I like it. For those of us who are not welders, but probably should be, this seems a good alternative. Thanks for the pix
   / Lifting hooks on NH7308 FEL #10
I can weld alright for a novice but I thought this made a cleaner bang up job. /forums/images/graemlins/smirk.gif
With four 1/2" bolts I don't think it will go anywhere. I have put some good stress on it so far and had no problems. I also have an oversized platform that fits right in and allows me to carry long objects such as conduit and steel I-beams etc. without having to lay it over my bucket cylinders and scratching all the paint off. /forums/images/graemlins/grin.gif
Pallet Fees (A50774)
2014 Whisper Watt Generator (A49461)
2014 Whisper Watt...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A51039)
2003 International...
