lifting finish mower
   / lifting finish mower #1
DavidS
Lufkin, Texas
Bolens G152
how do you guys stand up your finish mower to work on the underside?
   / lifting finish mower #2
Most guys I've seen out here who use something other than the 3 point lift use a chain and do it with the FEL. I just raise my 3PH up as far as it will go and get down low and spray away. Yep I tend to get a little wet while doing this. /forums/images/graemlins/grin.gif Hey it's summer time anyway. Good luck
   / lifting finish mower #3
I read a reply here from one guy that installed an eye bolt to the back of the mower. He attached a chain to the eye bolt and the other end to a beam or rafter. He would disconnect the top link (leaving only the 2 lower arms connected), raise the 3ph and pull the chain, thereby lifting the front and back of the mower. Hope I explained it to where you could understand it.
UNUSED IRGC40 MINI ELECTRIC GOLFCART (A57193)
UNUSED IRGC40 MINI...
UNUSED WOLVERINE TDB-11-78W 78" BUCKET (A57193)
UNUSED WOLVERINE...
Texaco Vintage Decorative Fuel Pump (A55853)
Texaco Vintage...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
UNUSED INDUSTRIAS AMERICA 180 HYD SCRAPE BLADE (A57192)
UNUSED INDUSTRIAS...
2006 TerraGator 8104 (A55315)
2006 TerraGator...
