'Leveling box' adjustable link for Kubota M4700 needed
   / 'Leveling box' adjustable link for Kubota M4700 needed #1
rv7charlie
Bronze Member
Kubota M4700
Hi,
My M4700 came with a pair of manual-adjust (disconnect to adjust) leveling links in the Cat 2 3PH system. I'd like to replace one with a true adjustable link; preferably one with a crank handle. But the 'genuine article from Kubota is priced at about $800 and I'm not going there. There are numerous devices available on line, but most list only brand/model of tractor they fit, which isn't much help. I'm hoping someone with a Cat 2 size hitch on their Case, Deere, etc can see if my dimensions are close to yours. Mine uses 3/4" pins top and bottom, lower end (fork) of the link has 7/8" opening (arm on the tractor is 3/4" thick), top of arm is 1 5/8" thick (tractor's upper (lift) arm opening is 1 3/4" inside), and the pin-to-pin length right now is ~18".
Something like this:
could work, if the pin-to-pin distance is under 16"; the Kubota link has a solid block at the top that transitions from the arm to the link.
Thanks for any help.
   / 'Leveling box' adjustable link for Kubota M4700 needed #2
Don't know where you're located, but I noticed that Rural King stocks a number of adjustable links. Didn't pay a lot of attention because I was shopping for something else, but I saw them yesterday along with their top-links.
Thanks for the tip, but no joy on Rural King. We do have several Tractor Supply locations, but their links are all made like a top-link, with a 'cross' welded on the body to turn it. That may be what I end up with, but the crank would be worth a little extra money if I can find one that fits.
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
2005 WINNEBAGO WORKHORSE W22 RV (A50854)
2005 WINNEBAGO...
2002 International 4400 SBA 4x2 (A49461)
2002 International...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2013 CAT 950K WHEEL LOADER (A50854)
2013 CAT 950K...
