leaky rear trans @ front axle e2004
   / leaky rear trans @ front axle e2004 #1
shady1701
my propshaft running from rear of trans to front axle is leaking i was wondering where the seal was and is ? any diagrams for e2004
   / leaky rear trans @ front axle e2004 #2
There is a flat gasket between the driveshaft tube and the trans.
Eugene
how would you get the driveshaft out does it have a u-joint at front and like a slip joint going into transmission?
   / leaky rear trans @ front axle e2004 #4
Take the front axle pivot pin out and drop down to clear botton of tractor. Remove bolts on rear tube flange and pull forward. It will slip right out. The gasket goes behind the flange.
Eugene
2019 Allmand Light tower (A49461)
2019 Allmand Light...
UNUSED 30PCS Heavy Duty Hinges (A50860)
UNUSED 30PCS Heavy...
2021 Bell B30E Off Road Dump Truck (A50860)
2021 Bell B30E Off...
2020 Chevrolet Malibu LT Sedan (A50860)
2020 Chevrolet...
ATV Racks (A50860)
ATV Racks (A50860)
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
