Leaking Solder Joint Need Suggestions
   / Leaking Solder Joint Need Suggestions #1
NY_Yankees_Fan
Veteran Member
Warren County, NJ (60 miles from NYC)
Kubota BX 2200
Need help/ suggestions...
I installed a new water softener to replace an old one yesterday. All the copper pipe joints held, but today I have a small leak in one elbow. The leak is at the connection to the old plumbing that had some water in it. I thought I got the water out before soldering, but I guess not. Of course this joint is trapped with water with no easy way to get the water out to drain it. So any suggestions to make a repair, do you think JB weld will work, how about a clamp, this is 1" copper pipe with about 60 psi well pressure on it.
   / Leaking Solder Joint Need Suggestions #2
If there is no easy way to drain the water then just cut the line, take your time draining the water and re-do the line. Don't waste time trying to reuse the connection, just replace it.
You might want to try and lift the pipe that is holding water to help drain any water in it. They also have little water plugs that are suppose to keep the water back but I have never used them before and don't know if they have one for 1" pipe.
I know from experience that the best way to fix the leak is to just tear it all apart as much as you don't want to. Good luck to you.
   / Leaking Solder Joint Need Suggestions #3
Fix it right, because if you don't it will pick the worst time to fail.
I remember the old advice of wadding up some white bread and jamming it up the pipe, then sweating the joint as fast as possible. The bread will burn/dissolve, and give you twenty seconds to get the joint set.
I've never used this advice, however.
   / Leaking Solder Joint Need Suggestions #4
i agree with robert. anything you try to apply on the exterior of the pipe (like JB Weld) is not a sure thing to hold. if you have trouble getting the water out of the elbow to unsolder it then drill a hole through the elbow so it can drain and then burn it off.
   / Leaking Solder Joint Need Suggestions #5
You have to replace it, but if you are not comfortable with sweating it back together with new fittings, you can redo it with compression fittings. I've had good luck using the ones that go from copper to CPVC on some water heater jobs where it was faster and cheaper for the client. In several years of using them, I've never had a call back for a leak or any other problems.
Eddie
   / Leaking Solder Joint Need Suggestions #7
As a 35 year plumber, your advice so far is correct start over, clean with sand screen, and steel wool, when clean, clean some more LOL. Your best friend in a case like this is a wet & dry vacuum, you can use it to pull the water out. Then if you still have water coming open a faucet, or open the system up stream and put the wet & dry there as you solder. Also a union close to the problem is help full, you can solder with the union apart, then connect after it's soldered, if you have a problem you can pull the union apart again and start over soldering. Not a real fan of sticking stuff in the pipe, ie. bread ,toilet paper, etc.
Good Luck!
   / Leaking Solder Joint Need Suggestions #8
Turn off water.. drain lines, leave faucets open so air pressure don't blow solder out of joint while it tries to wet / tin.... hit it with alotta paste flux, then start waving your magic propane torch around and have your silver solder ready..
No wat to shortcut this one with goop or clamps..
soundguy
   / Leaking Solder Joint Need Suggestions #9
Doc, I, too, had heard of but never used the white bread method. However, this summer, my son-in-law used it on an outdoor hydrant on a house he's remodeling and it worked fine. But then one day when I was over there helping a little, he had to try it again on another outdoor hydrant. The only trouble was that we had no white bread, but we did have some cinnamon rolls I had bought on the way over there. It did work, but we began to think we were going to have to take everything apart and start over before the water pressure finally blew that that stuff out of the line.:D
   / Leaking Solder Joint Need Suggestions #10
You have to bake off the water if you can not drain it. Use MAP gas instead of propane. It is hotter and the pros use it because it takes less time to swett joints. I had a 1 1/4 " fitting give me fits when i was cutting in a heat exchanger. I had to completely remove the 90, fully clean and paste, then solder. It is very hard to just reheat the joing and add solder. So take the extra time to fully remove the fitting clean and resolder.
2004 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2004 Big Tex 10PI...
Landscape Rake (A50860)
Landscape Rake...
2011 New Holland B95B Cab MFWD Loader Backhoe (A51039)
2011 New Holland...
2009 JACK COUNTY 130 BBL VACUUM  TRAILER (A50854)
2009 JACK COUNTY...
2007 Terex RS350 Soil Stabilizer/ Reclaimer (A49346)
2007 Terex RS350...
CHALLENGER VACUUM PUMPS (3) (A50854)
CHALLENGER VACUUM...
