Leaking front tire
   / Leaking front tire #1
JerseyMike
John Deere 3005
This is my second post and second tire question :(
I have a John Deere 3005 with R4 tires. my left front tire is leaking air. I went to a tire shop and he said it was the valve stem, which I paid to replace and it's still leaking. Looking at the tire there is a gash along the inner sidewall that extends to the bead and is fairly deep. I suspect that it is the cause of the leak.
My question is, do I need a new tire (which would mean two new tires so that they are worn the same) or can I do one of the following:
1. Slime the tire
2. get an inner tube installed in the tire
any help is appreciated. BTW the tires are Titan 25x8.5-14 6-ply R4's
-Mike
   / Leaking front tire #2
A boot inside the area weakened by scratch then a boot would extend the time before the tires needed replacment.
ken
   / Leaking front tire #3
I'd sure fix it, maybe at a truck tire shop. Patch tire from inside, add tube. Maybe your valve stem AND the gash were both seeping air.
Jim
   / Leaking front tire #4
You could try slime and if that don't work install a tube.:D
   / Leaking front tire #5
Mix up some dish soap in a spray bottle so you can wet down the tire while looking for bubbles to find out where the leak is in the tire. "Fixing" a leak that may or may not be there is a sure formula for frustration. The first step is to be certain where the leak is and then fix it based on that. A leak around the tire seating bead at the wheel may not be fixable with slime. It may require breaking down the tire, cleaning the area, and using some bead sealer. If the leak is somewhere away from the gash on the bottom or shallow sidewall, slime would be a good solution. If the leak is in the gash, then a boot inside the tire or a tube would be best. If you put a tube into the tire, be sure to run your hand around the inside to feel for thorns or other sharp objects that may puncture the tube. You don't want to have to pull the tire again to fix a problem right after putting in the tube.
   / Leaking front tire #6
If it's leaking at the bead, you would have to fill the tire with slime to make it works... and slime doesn't last... at least for me :eek:
   / Leaking front tire #7
If slow bubble leak and gash not to deep or long I'd tube it,but if long gash tire low in couple days I than would replace..you maybe distance from your home or in mud etc. when tire goes flat quickly,and that can be long wasted day. :(
Well, I had some slime sitting around so I slimed it tonight, well see how it works
1968 John Deere 4020 with 7ft Mower (A51039)
1968 John Deere...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
2007 Hyundai Santa Fe SUV (A49461)
2007 Hyundai Santa...
2022 Continental 16' Enclosed Trailer with ramps (A49461)
2022 Continental...
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
