Land Pride Rear blade customized
   / Land Pride Rear blade customized #11
Re: Land Pride Rear blade customized
Your RB w/ hydraulics looks great, nice job. Your project and pictures have rejuvinated a recent idea I had for myself.
After seeing yours, I want to do mine even more.
I am going to convert my LP72 rake into a hydraulic angling rake by using the angling rams ( if possible ) from my Fisher snowplow. The design and application as I figure it in my head doesn't seem to difficult. I will just mimic what the did with the plow. After all. I am merely asking the rams to perform the vary same task. It will just be behind me and not in front of me.
If my idea is succesful, I can use the hydraulic rams on the plow during the winter and then just shift them over to the rake for warm weather.
Thanks for the pics and the post. I now have my spring project. /forums/images/graemlins/grin.gif
Well ok, Another spring project !!! /forums/images/graemlins/tongue.gif
   / Land Pride Rear blade customized #12
Mark the projects just never seem to end do they? /forums/images/graemlins/wink.gif
   / Land Pride Rear blade customized #13
</font><font color="blue" class="small">( the projects just never seem to end do they? )</font>
Mike,
That doesn't bother me as much as the day the list DOES end. /forums/images/graemlins/frown.gif /forums/images/graemlins/tongue.gif
   / Land Pride Rear blade customized #14
<font color="blue"> That doesn't bother me as much as the day the list DOES end.
</font>
How true... how true....
Thanks guys,
For the record I only have hyd top link, no tilt. I only have two remotes on the back. The two for the front are used for loader or snow blade.
DDT
   / Land Pride Rear blade customized #16
Harv Im using a solenoid valve from Surplus Center to make a friends grapple bucket i built work on his new tractor. It was 149 dollars there. You could make your auxhilary run one function all the itme thats the most importan. For a dozer blade the lift and the tilt. Im taking youll use the boom to lift the blade. The secondary funtion the angle would be best done with the solenoid valve and switch since its the least used. It just tee's off the line to the main function and diverts the flow to the extra cylinder when used. Thats usually the best way to get 2 functions from one 2 way valve. Take care Taylor Lambert
2022 Ford Escape S AWD SUV (A55853)
2022 Ford Escape S...
2014 Chevrolet Traverse 2LT SUV (A55853)
2014 Chevrolet...
40' CONTAINER (A51244)
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
2016 Ford F-450 Ext. Cab 4x4 10FT Flatbed Truck (A51692)
2016 Ford F-450...
