Land Pride broadcast spreader
   / Land Pride broadcast spreader #11
I like the land Pride 500 pull behind best, wife can run spreader and I come behind her with cultipacker, sometimes you don’t have a lot of time to get ahead of rain.
The big benefit to pull behind is that ground speed and height are removed from the equation of consistent spread. Height remains basically constant and the speed of the broadcast spin is controlled by ground engagement of the wheels. From my experience and from watching others, these ate the 2 biggest inconsistencies with 3PH broadcast spreaders.
   / Land Pride broadcast spreader #13
Reading thru the comments, someone said the downside was it was not quick hitch compatible which is probably a no-go for me.
I don't see anywhere that the other one is...:confused3:
   / Land Pride broadcast spreader #14
My pto spreader works great but i wish i had went with a pull type. You can pull them with anything keeping your tractor freed up for other things. I f you have lots of time then no big deal.When i am putting in fall food plots im usually in a hurry with tilling packing and seeding . Changing implements can be a pain even with a QH, especially when you have to go back and forth a mile or so. King cutter pull type is around 800 bucks.
2018 Ford F-550 4x4 Stellar EC3200 1.5 Ton Crane Service Truck (A55852)
2018 Ford F-550...
2023 Chevrolet 1500 Silverado Z71 Crew Cab Pick-Up Truck (A55852)
2023 Chevrolet...
UNUSED PABREAK DB220-84" HYD DOZER BLADE (A57193)
UNUSED PABREAK...
UNUSED FUTURE D3T 32" EXCAVATOR HYD TILT BUCKET (A57193)
UNUSED FUTURE D3T...
49205 (A55788)
49205 (A55788)
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A57192)
UNUSED SET OF...
