Land plane, how low to set the blades?
   / Land plane, how low to set the blades? #1
jenkinsph
Super Star Member
somewhere usa
Deere 110tlb, 4520, x749, L130
I am building a landplane which is 96" wide with 60" runners. It will weigh about 700 lbs. My questions are should I make the blade angle adjustable and how should I set up the grader blades as far as depth?
I have seen both angled blade and straight blade drags, my intention is to use it for driveways some but primarily for ground planing and smoothing. I am not concerned with building a crowned roadway either.
Should the grader blades be slightly below the side runners or even with them?
Steve
   / Land plane, how low to set the blades? #2
I built mine 3/4" below the runners. Mine is 5' wide and weights 650 lbs
waterguy,
I have a heavy duty 7' boxblade (Frontier 1284) which weighs about 1200 lbs to do the heavy cutting. I am hoping to use the landplane for finish work and touchups. How much weight did you try first?
Steve
2016 Volvo A25G 20CuYd Articulated Dump Truck (A49346)
2016 Volvo A25G...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
1-Pallet Misc. Power Tools (A50860)
1-Pallet Misc...
2021 Kubota SVL97-2HFC Compact Track Loader (A50657)
2021 Kubota...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
