Land plane, how low to set the blades?
   / Land plane, how low to set the blades? #1
jenkinsph
Super Star Member
somewhere usa
Deere 110tlb, 4520, x749, L130
I am building a landplane which is 96" wide with 60" runners. It will weigh about 700 lbs. My questions are should I make the blade angle adjustable and how should I set up the grader blades as far as depth?
I have seen both angled blade and straight blade drags, my intention is to use it for driveways some but primarily for ground planing and smoothing. I am not concerned with building a crowned roadway either.
Should the grader blades be slightly below the side runners or even with them?
Steve
   / Land plane, how low to set the blades? #2
I built mine 3/4" below the runners. Mine is 5' wide and weights 650 lbs
waterguy,
I have a heavy duty 7' boxblade (Frontier 1284) which weighs about 1200 lbs to do the heavy cutting. I am hoping to use the landplane for finish work and touchups. How much weight did you try first?
Steve
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 567...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A56435)
2018 John Deere...
PALLET OF 250 TRAFFIC CONES (A58214)
PALLET OF 250...
202481 (A54757)
202481 (A54757)
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
