L4740 AND TIRE CHAINS CLEARANCE
   / L4740 AND TIRE CHAINS CLEARANCE #1
Green Acres Homestead
Veteran Member
NewBrunswick & Nova Scotia www.lostcaper.com
Kubota L4740 sold. As of Jan 2023 I have a new L2502.
I have a Kubota L4740 and looking at getting tire chains. There is about 2 inches of clearance from tire to frame. I cannot space out the tires any farther because my snow blower is a 72 inch. So is there enough clearance for chains without banging against the frame and taking my light wiring out? Does anybody have any experience with this?
   / L4740 AND TIRE CHAINS CLEARANCE #2
I just got some roadmaster ladder type chains for my L3400, and although I have wheel spacers which set the wheels out 1.75", giving plenty of clearance, I think ladder type chains might be you best bet. Just make sure there aren't any loose ends flapping around- tie everything in, and you should be okay, but not by a lot. Ladder style are pretty thin compared to some, taking up maybe an inch or so. Maybe you can see a difference between my old tractor's chains, and the new ones? EDIT: I checked, and even my chains add almost 2" on the inside of the tire, so you will have to find something really thin.
   / L4740 AND TIRE CHAINS CLEARANCE #4
The particular chains would vary, of course, but mine look like 1.5" is the chain's max. thickness, so add an inch or so for "clearance" and you are looking at roughly 2 1/2" from the tire's sidewall to the fender metal.
thanks
2011 L3 MEP-806B GENERATOR (A51222)
2011 L3 MEP-806B...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
3014 (A50657)
3014 (A50657)
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
(INOP) VOLVO L70H WHEEL LOADER (A50459)
(INOP) VOLVO L70H...
1043 (A50459)
1043 (A50459)
