L4701 Right front turning axle leaks on the tire
   / L4701 Right front turning axle leaks on the tire #1
Stan777
Kubota L4701 RTV 1100C
It started this at 100 hours. When I went to investigate 2 years ago, I opened the check nut and air rushed out. I thought" its under pressure"? Then it was only about 1/2 pint low. It stopped leaking. I read that other larger tractors have the same issue. Anyone know anything about this issue?
Then this year under heavy use it started leaking again. Still a small leak, and no pressure when I remove the nut. How hard is this to repair if I have tools? And are any special tools needed to get this done?
2020 Barreto 20RTK 36in Stand-On Trencher (A49461)
2020 Barreto 20RTK...
CAT ENGINE ( NON- RUNNER) (A50854)
CAT ENGINE ( NON-...
72in Rock Bucket Skid Steer Attachment (A50322)
72in Rock Bucket...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2013 Doyle Dry...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
