L4150DT Algae Nightmare Cannot Bleed Motor
   / L4150DT Algae Nightmare Cannot Bleed Motor #1
nightowl490
Corrupt Illinois
L4150DT
Pushing brush, moving downed trees, prepping foot plots, then she coughs and sputters. No fuel in sediment/filter bulb, pulled off tank line at pet cock and an algae turd comes out then gushes fuel. re-attach line, remove filter, some algae goob but not blocking filter. Re-Bled bulb and began bleeding process......... I cannot cannot get it do any more than cough. I have had fuel lines removed/replaced and have bled before but something feels a miss this time. I kept battery from draining and kept up the 10 second bleed process but no luck...... I have posted on this before but am hoping for some new tricks.
Also, by the way, I talked to Ronnie at Tractorsmart (Great Guy) and he no longer offers specialty parts for Bota. Looks like it's on to Messick's? Thought I would update a few things on tractor for the year.
Anyone??
   / L4150DT Algae Nightmare Cannot Bleed Motor #3
If you have algae in your fuel tank you must clean it out completely.
Drain the tank, rinse it with some clean diesel, then re-fill with fresh fuel and add some biocide treatment that will kill any remaining algae.
You might have to change the filter a couple of times before all the gunk is gone.
Update
Couldn't take it anymore, pulled off lines as recommended., had good pressure but lots of bubbles.. Completed bleeding process and whaallaaaa.... Coughed and fired, ran for two hours no worries... never underestimate bleeding process!!
Update complete., thx for info, lead to success!!!
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
More info coming soon! (A49346)
More info coming...
2006 International 4400 LP Crew Cab Heavy Haul Truck Tractor (A49461)
2006 International...
2005 John Deere 824J Articulated Wheel Loader (A49461)
2005 John Deere...
MAXUM M-1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM M-1000...
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
