Price Check l4150 tlb
   / l4150 tlb #1
bmainer
Hi, all! Im looking at a l4150dt with a bf 900 fel and a l4540a backhoe. with 2500hrs two rear remotes and seems to be in all around good shape! I have no idea what year it is but all oils look new any idea what a ball park price might be? thanks for you time1 B
   / l4150 tlb #2
The L4150 started production in the early '80s and was sold thru 1990. It's official "year" was the year it was first sold at retail. They gave it a couple minimal changes and a new model number (L4850) starting in 1991. The last L4850s sold around 1997. These tractors are beefy, strong, beautifully over-built, designed to last forever. That said, however, 2500 hours is long enough that if a machine has been abused, it shows - especially if it has a backhoe.
The money on these rigs is in the hydraulic shuttle (if it has it) and in the loader and backhoe hydraulics. Test the backhoe for down force - with the stabilizers down (back end of the tractor lifted off the ground) see if the backhoe will lift the back end still higher to shift the whole back end of the tractor sideways. If not, then the pump is worn ($$$). Same thing with the loader - it should be able to lift the front axle off the ground with the back of the tractor already up on the stabilizers (backhoe tucked in so it's a minimal counterweight). If it can't the machine has hydraulic wear that probably extends to all the piston seals, control valve spools, transmission shuttle valves and clutch packs etc, etc and is likely to be a constant hole in your checkbook. My 2 cents. I have one of these machines - it has 1100 hours and is in very nice shape (tight). But I've seen some for sale that are loose. It all depends on how it's been used and if the fluid has been changed out when it gets dirty.
A fresh tight rig with strong pumps, good rubber, tight valves, etc,etc. might be worth $22k. But a worn one might only be worth half of that. If you can hire a TLB mechanic to go look at it with you it might be money wisely spent.
2016 Ford Fusion (A50324)
2016 Ford Fusion...
John Deere 570-A Motor Grader (A50860)
John Deere 570-A...
2009 L3 GENERATOR SET (A51222)
2009 L3 GENERATOR...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A51039)
Neckover GL24-2-7K...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
