Hello, I have spotted a L4150 for auction. Ihave never had anyhing to do with a kubota before. It states "front driveshaft removed, and steering needs work". Can any one tell me why these parts fail, ie weak, old age etc?
The L4150 was a very robust model - failures in the front drive were very rare, usually from gross abuse. Removing the front driveshaft would mask a broken gear that makes noise when shifted into 4wd. A steering issue could be bent or broken tie rods, pitman arm, etc, or failed hydraulic steering box ($$). I'd guess the bids will be very low. Pretty important to have a close look unless it's under $2-3k and you're adventurous. BTW the hour meter cable on these routinely breaks at around 1000 hours - can only estimate actual hours from overall condition.
