L3901 Complete Power Loss after 30 mins with PTO operation
   / L3901 Complete Power Loss after 30 mins with PTO operation #12
If it over-heated a half dozen times to the point of stalling each time, wouldn't the damage to the engine start to be noticeable? I would expect it to at least run oddly. Just playing devil's advocate.
Could it be as simple as a seat switch that is making partial contact?
Very interested in seeing what happens here.
BTW - I mow a dozen or so properties with my L2501 and 5ft brush-hog. Heavy grass, STEEP hills and summer temps. No issues with overheating. However I have had issues with the little switch and PTO cable sticking. But that usually leaves me with either a no-start or the PTO is stuck on.
Depends on if the engine killed itself or a sensor shut it down.
   / L3901 Complete Power Loss after 30 mins with PTO operation #13
No re.sponse from op? Curious.
   / L3901 Complete Power Loss after 30 mins with PTO operation #14
Problem is. Kubota motors are notorious for blowing head gaskets when overheated. Actually the weak point in an otherwise very stout motor and if so, will require a head removal and a check for flatness plus a new OEM head gasket.
2019 KUBOTA SVL75-2 SKID STEER (A52707)
2019 KUBOTA...
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
Kubota L3130 (A53317)
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
2019 KUBOTA R630 WHEEL LOADER (A52707)
2019 KUBOTA R630...
2022 Polaris Ranger 4x4 Utility Cart (A55851)
2022 Polaris...
