L3540 and 40 sheets of OSB (1880 lbs)
   / L3540 and 40 sheets of OSB (1880 lbs) #1
tmc2318
Saskatchewan , Canada
2007 L3540 HST Cab
I was again impressed with my 3540 and LA724 loader today when I ordered 40 sheets of 4' x 8' OSB for sheeting my garage. Not really sitting down to calculate what that might weight I assumed it to be in the 1000 lb range. This morning the truck showed up with the stack banded together. The top of the flatbed truck was at least 5' as I approached it with my pallet forks. The stack was larger than I imagined but got under it with my 36" forks and pulled back on the controls...nothing. Throttled up and got it to lift - backed up slowly and when the driver gave me the thumbs up I lowered very carefully as I knew I was pushing it. Lifted it again and set it in my garage. When I found out that each sheet weighs 47 lbs that works out to 1880 lbs for 40 sheets - at a center of mass 24" out + approx. 300 lbs for my forks. Impressive!
   / L3540 and 40 sheets of OSB (1880 lbs) #2
I also have the 3540/724 and it is an impressive loader. I load 1600 # pallets of fertilizer into my trucks every other day. I use 36" bradco qa forks, low gear in low range, a 1000# weight box out back & i throttle up to 2500 rpm. No problems with this load what so ever!
2022 Club Car...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2014 Fiat 500L Hatchback (A48082)
2014 Fiat 500L...
Caterpillar D5K2 LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K2...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
