L35 wiring Diagram needed
   / L35 wiring Diagram needed #1
ChrisR
Henley Brook, Westen Australia
Kubota L35
Hi
Has anybody got a copy of the wiring Diagram for the kubota L35. The back of my fuse box has just about corroded away, and when I removed it to replace it, the wires popped out and I haven't a clue where they should go in the new fuse box?
Here's hoping
Chris
   / L35 wiring Diagram needed #2
Not what you want but they might give you some clues ...
  • L2500DT_Wiring.pdf
  • L2500F_Wiring.pdf
Thanks very much for posting the diagrams Alchemysa
Unfortunatly they bare no relationship to the L35 so I'm back to square one.
I have also discovered that while the new fuse block has come with fuses, the actual metal male connections that the cable female end would fit on are not there? in fact there is no metal in the block at all, just a lot of plastic slots.
Any suggetions
Chris
   / L35 wiring Diagram needed #4
Hi Chris,
I'm on my way to work right now, but I do have a shop manual for the L35. PM me (to remind me) and I'll make a copy of the wiring diagram this afternoon/evening, sorry I can't do it right now.
   / L35 wiring Diagram needed #5
Let me know if this is good enough Chris.
   / L35 wiring Diagram needed #6
As per your PM, here's the center section.
Hopefully this will do it for you Chris.
   / L35 wiring Diagram needed #7
Currently have a start problem, also. Thx for the help. Super dimmed lamps on the dashboard only light after the key is in the first “ign. on” position. This occurred after a completely normal start and shutdown. New battery, good connections. Hmmmmmm… down the rabbit hole…..
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
CFG Industrial MX15RX (A56469)
CFG Industrial...
IRanch Dump Hopper (A55851)
IRanch Dump Hopper...
Nissan CF60 6,000lb LP Forklift (A55851)
Nissan CF60...
CATERPILLAR 20" PIN ON BUCKET (A52707)
CATERPILLAR 20"...
2004 EAGER BEAVER 50GSL/3 DETACH TRAILER (A57192)
2004 EAGER BEAVER...
