L3130 GST 5th and 6th gear noise
   / L3130 GST 5th and 6th gear noise #1
golfgooroo
When either shifting up or down to both 5th and 6th gear, there is a pinch noise. I wouldn't quite call it grinding, but it is quite loud and doesn't sound harmless. When in those gears at idle, a louder hummm can be heared than other gears as well. It seems to perform fine in these gears, but I want to know how to remedy the problem if there is one. Thanks for your help!
   / L3130 GST 5th and 6th gear noise #2
Mine has always done that in 5th and 6th from day one and now has over 1,000 hardcore hours on the clock, not a problem.
   / L3130 GST 5th and 6th gear noise #3
Can't say as I've ever noticed that in any gear on mine. How many hours do you have on it? It may just be the way the gears have meshed as you've broken it in.
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A50397)
1989 Freightliner...
2010 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2010 TROXELL...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
2015 INTERNATIONAL 4300 26 FT NON CDL BOX TRUCK (A51219)
2015 INTERNATIONAL...
UNUSED Artificial Grass Turf (A50860)
UNUSED Artificial...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A51039)
Toyota 6FGU25...
