L3000DT steering problems
   / L3000DT steering problems #1
Snook
I own a Kubota 3000dt. Early 2000’s model. The steering column becomes loose as the bolts holding it back out. As they are through holes when it gets loose it leaks hydraulic fluids. The tiny metric fine threads stripped years ago and former owner retaped with a course standard bolt and it is better but still backs out. Any suggestions to hold the bolts in better? Or a more permanent fix? Thought about wiring the nuts together to prevent movement and loosening but don’t know that will work.
All ideas welcome
Thomas
   / L3000DT steering problems #2
Blue LocTite?:My son has that very tractor and haven't had that problem.
2007 CHEVROLET SILVERADO 4X4  DUALLY TRUCK (A51222)
2007 CHEVROLET...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
2019 Ford F-550 Bucket Truck (A51039)
2019 Ford F-550...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
John Deere 570-A Motor Grader (A50860)
John Deere 570-A...
Char-Broil Gas Grill (A50860)
Char-Broil Gas...
