L vs M series Kubotas?
   / L vs M series Kubotas? #11
When I upgraded, I looked at the MX vs M. Went with the M series. Heavier tractor, higher hydraulic capacities.
Bought a brand new 2009 M6040. It's been an excellent tractor.
There are a very few times - wish I'd have gone bigger, same with going smaller. The M6040 hit a sweet spot for my needs.
   / L vs M series Kubotas? #12
I liked my little M7040. Tough little bugger. Pulled a round baler!
   / L vs M series Kubotas? #13
Yes please update your original post to L vs MX if that is the case. The M series is Ag Utility, no HST transmission offering (gear only)...just a machine built for different purposes than a compact (L) or compact utility (MX).
yes, MX series is in a mid range series between L & M, but a far cry from the M series. MX is a decent tractor, had a 5000 once. bare bones & solid, a slight notch above the L series, not much though (once owned a L4400 as well).
definately test drive the MX extensively to get the feel over the L best regards
   / L vs M series Kubotas? #14
L and MX nice tractors, but I’d rather have a lightly used M than a new MX or L
   / L vs M series Kubotas? #15
I started off with an L4630 GSTC and loved it but it was aging and I wanted to get into something bigger.
Found a used pre-tier 4 M6040 DTC for a great price and snapped it up.
The M is a beast compared to the L in all categories. Larger wheels, much higher loader capacity and of course 15 more hp.
   / L vs M series Kubotas? #16
I have a MX5200 and it is one solid stable machine
With a 900 pound grapple on front it can still life huge logs
Andy
   / L vs M series Kubotas? #18
Good commentary on MX versus M tractors. They are not the same at all.
   / L vs M series Kubotas? #19
Well, they are both orange:ROFLMAO:
   / L vs M series Kubotas? #20
From L, to MX, to M. the OP has the good sense to inquire. IMHO the step from L to MX is a small one. the next step from either L or MX to M series utility tractor is a big one. Jeff & sea2summit explained that well in above posts My experience has been the same. The MX series has always struck me (from ownership of both) to be a wannabe M series tractor. The OP should carefully explore the reasons from stepping up from current L series for current & future needs. Any upgrade shoud be to solve a specific need. the future need forecast sometimes gets complex
personally, i'd never consider going back to MX with my current tractor, but each owner has their own needs. & more importantly, their wallet... best regards
10' CONTAINER (A57193)
UNUSED RAYTREE RMBD50 50" HYD DRUM MULCHER (A57193)
UNUSED RAYTREE...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
2007 Cub Cadet Gas Utility Cart (A55851)
2007 Cub Cadet Gas...
1997 FORD F-SERIES DUMP TRUCK (A57192)
1997 FORD F-SERIES...
ECHO CS-4010 GAS CHIANSAW (A57192)
ECHO CS-4010 GAS...
