Kubota SVL 90-2 Chugging Under Load
   / Kubota SVL 90-2 Chugging Under Load #11
Glad to hear it was just a fuel filter problem, but watch out next time - they will probably still want you to replace the injectors just waiting for the next chance!
   / Kubota SVL 90-2 Chugging Under Load #12
I was thinking about this thread. You might investigate what stopped the fuel filter up. Maybe check the hose clamp on your filler neck. Maybe the rubber washer on your cap. Might be worth wile to drain tank. I have seen a couple svl videos where the fuel line to the water separator gets clogged right at the water separator.
   / Kubota SVL 90-2 Chugging Under Load #13
They already replaced his DPF system when it maybe is fuel injectors causing repeat failure of emmission systems. The OP has two problems: excessive water in fuel system and possible bad injector.
   / Kubota SVL 90-2 Chugging Under Load #14
Was thinking the same thing. If it's a fuel problem, start at the source (what's in the tank), and follow the flow toward the combustion chamber until you find the problem.
   / Kubota SVL 90-2 Chugging Under Load #15
The most obvious place for material to enter the fuel is from refueling. Sooner or later debris will find its way into the tank no matter how careful you are. The solution is to have a fine screen in the filler neck that stops anything but fuel from getting into the tank. However, this will not catch any downstream occurring contamination.
2018 John Deere Z997R (A53317)
2018 John Deere...
2019 Ford F550 Chassis (A55973)
2019 Ford F550...
(4) 775/65R29 TIRES (A57192)
(4) 775/65R29...
2015 Chrysler 200 Sedan (A56859)
2015 Chrysler 200...
UNUSED IRANCH 1RTPL 10,000# TOW POST LIFT (BLUE) (A57193)
UNUSED IRANCH...
Yamaha (A55758)
Yamaha (A55758)
