Kubota post hole digger question
  • Thread starter Deleted member 347538
  • Start date
   / Kubota post hole digger question #21
Our Land Shark Post Hole Digger(click the link for prices, details, and almost 100 customer reviews) is the best one ever made for subcompact tractors.
Check it out on our B and BX here:
The geometry is spot on for smaller tractors, unlike most others on the market..
As some mentioned, using a full sized model could land you like this, or worse..
It is also VERY stressful on the toplink housing..
Since the video, we've even improved our design. The hoop is now over the boom with adjustments!
Ships to your home via FedEx ground, free within 1,000 miles of Conover, NC.
I hope this helps.
Travis
   / Kubota post hole digger question #22
They make all sorts of PTO transmissions. Rear vs mid. Standard vs “economy” mode etc, but....
What applications would a reversible PTO be useful for?
PHD
Rototiller? Maybe not.
Unplug a snowblower? Maybe not.
A chipper, as a way to sharpen blades? (Didn’t some corn choppers have this method? Reverse direction than move a “built in” sharpening into place.) Maybe not.
   / Kubota post hole digger question #23
Over last 3 years, i have drilled close to 200 post holes with my Woods 9" auger. All drilling has been in clay type soils. And you do need to build up a level of experience. I typically auger down at 1 foot increments, and clean out the hole by lifting up. Go back in and make another foot of hole, then lift and clean out the hole again, continuing to do this until proper hole depth is reached. I only bury the auger now about once every 10 holes. This spring, have another 50 holes to make for a split rail fence.
(APPROX 125) UNUSED TRAFFIC CONES (A57193)
(APPROX 125)...
UNUSED WOLVERINE PFA-113300G 48" PALLET FORKS (A57193)
UNUSED WOLVERINE...
1987 Landall 48ft 35 Ton Hydraulic Slide Axle T/A Drop Deck Trailer (A55852)
1987 Landall 48ft...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2018 RoGator 1100C (A55315)
2018 RoGator 1100C...
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
