Kubota post hole digger question
  • Thread starter Deleted member 347538
  • Start date
   / Kubota post hole digger question
I hear ya. I’m sure itll happen to me early on but lesson learned. Thanks for the reply.
   / Kubota post hole digger question #12
If you lived close to me you could use my post hole digger......
I appreciate that but we’re ages away. Lol.
   / Kubota post hole digger question #14
I’ve read that a few places where you have to dig and retrieve, dig and retrieve as you slowly work your way down. That was my plan from the start. Glad to hear you’re able to run it. Thank you for the reply.
^This. Small bites. Lower, dig for couple inches, raise, let dirt spin off, repeat.
Many a digger has taken too big of a bite only for auger to corkscrew into ground and not have enough 3 point hitch power to raise it back out. PTO has no reverse. Never done it, but I hear turning a stuck one backwards by hand is no fun.
What size auger are you looking at running?
   / Kubota post hole digger question #15
I'm replacing 550' of split rail this spring, and got an ssqa mounted hydraulic auger to replace the 3pt auger. It should be fun.
Sorry to take this thread sideways, but what auger did you get that worked for your tractor's flow rate? I might need an auger soon.
   / Kubota post hole digger question #16
I don't know about your tractor and post hole diggers, or the gear box on the Countryline post hole digger, but I can comment on the auger itself. I have a 37 hp tractor and I bought a Leinbach Line post hole digger with a terrible auger. I replaced it with a Speeco auger that was a lot better, but the replaceable cutting teeth would wear out quickly. The store I bought it from had a few in stock, but when I bought all of them, they never got any more. So in desperation, I went to Tractor Supply and bought a Countryline 12 inch auger.
The Countryline auger was so much better at digging then what I had before that I cannot even compare how good it is. It went through my summer baked hard red clay like butter. Then when it hit what I call the concrete grey layer of clay, it went right through that too!!! In fact, it drills so quickly that I have to make sure to slow it down because it will bury itself and I don't have enough power to turn it once it's all the way in the ground. I have a 24 inch pipe wrench that I put a 8 foot pipe onto for more leverage that will unscrew it, or I can just use my backhoe and pull it out of the ground and make the hole twice as big as it comes up. I've done this a dozen times now, and it's always something that I promise myself that I will never do again. But then I do it again.
I got the crazy idea to buy a 6 inch auger for some smaller holes so I wouldn't have to fill as much material around them. That went in even faster and so deep that it bent my driveshaft. That might be the biggest mistake I ever made in drilling holes!!!
If I was buying a 3 point post hole pole hole digger today, I would take the chance on the Countryline gear box and auger. I would not want an auger less then 12 inches. I've done enough fencing to know how hard it is to keep 3 posts in perfect alignment. More fence posts are even harder. It doesn't matter how perfectly you start the hole, it moves as it's going down. Roots, rocks and softer dirt will all change where the hole is and you will have to use a clam shell digger to manually shave off one side of the hole to get it perfect. A smaller auger will mean more digging by hand to line up your posts.
   / Kubota post hole digger question #17
Was wondering the same thing?
I rented a bobcat version for my fathers skid steer but didn’t think a 3rd function on our machines would turn one.
   / Kubota post hole digger question #18
It's a Land Pride SA20, with the low flow head. Messicks demoed one on a smaller machine than mine on YouTube, and it seemed to do ok. The low flow head is rated for 6-10gpm flow.
I've only drilled a few test holes and it did fine in my Maryland clay. The auger doesn't spin as fast as my 3 point auger, but that's not really a fair comparison. The down pressure and reversing the auger should be awesome!
   / Kubota post hole digger question #19
Thanks.
   / Kubota post hole digger question #20
I know this has been asked before, but I’ve never heard if it works: Has anyone ever got the auger stuck and then (manually) turned the PTO shaft backwards, taking advantage of the PHD’s gearbox reduction?
(2) 12' 4" HEAVY DUTY SUPPORT RACK W/ WHEELS (A57192)
(2) 12' 4" HEAVY...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
ATTENTION! PLEASE READ (A53317)
ATTENTION! PLEASE...
UNUSED FUTURE FT-FR60 60" SIDE SHIFT FORKS (A57193)
UNUSED FUTURE...
New Holland T2420 (A53317)
New Holland T2420...
2014 Mack CXU613 T/A Wet Kit Day Cab Truck Tractor (A55852)
2014 Mack CXU613...
