Buying Advice Kubota or Kioti or Mahindra or LS or McCormick????
   / Kubota or Kioti or Mahindra or LS or McCormick???? #71
could they have been running a free FEL? anyway i dunno. but when i was shopping the cheapest was the LS at 225xx and the most expensive was the JD at 293xx. the LS didn't make the final list.
   / Kubota or Kioti or Mahindra or LS or McCormick???? #72
To a certain extent prices are regional of course; if you're looking at comparing apples to apples, without discount programs, there are differences that far exceed $2K-$3K on comparable HP tractors. I shopped for nearly two years and found significant differences in prices. That said, nothing wrong with shopping by discount programs either.
   / Kubota or Kioti or Mahindra or LS or McCormick???? #73
I would think not, since you bought a machine that's a step up in size. You'd have to jump up to a U5030 with the LL5102 FEL to compare similar machines.
   / Kubota or Kioti or Mahindra or LS or McCormick???? #74
i was looking at the 50ish HP compacts and utilities. all the compacts were smaller than the compact i currently had (except for the mahindra 5035 and the JD 4720), so i moved up to utility szied, for the LS i looked at the 5020 with a LL5101 it also didn't make the final list.
   / Kubota or Kioti or Mahindra or LS or McCormick???? #75
I think you've made it perfectly clear that you're not fond of LS, but the 5020 is also less powerful, and quite a bit lighter (1,000lbs) than the tractor you did buy….again, not really a direct comparison. Not that any of this helps the OP...
   / Kubota or Kioti or Mahindra or LS or McCormick???? #76
At what point does a CUT become a Utility size machine?
   / Kubota or Kioti or Mahindra or LS or McCormick???? #78
When you can use class 2 implements. HS
My Massey has Cat 1/2 links, and can lift 3,100lbs at the ball ends, so I could use Cat 2 implements, but I'm not sure it qualifies as a Utility sized machine (4,100lbs).
   / Kubota or Kioti or Mahindra or LS or McCormick???? #79
I was checking to see if the op posted back with an update on his search...I see this thread went off topic! LOL........
PJ  32 FLATBED GOOSENECK (A58214)
PJ 32 FLATBED...
2007 Honda CR-V SUV (A56859)
2007 Honda CR-V...
LOT: Assorted Hand Tools (A59076)
LOT: Assorted Hand...
2014 Ag Spray Schaben Sidedresser (A56435)
2014 Ag Spray...
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
NEW HOLLAND 105 WORKMASTER MFWD TRACTOR (A52708)
NEW HOLLAND 105...
