Kubota M95 Hydraulic issues
   / Kubota M95 Hydraulic issues #1
Bullseyefarms
Kubota M9540
Hey all, looking for a little input here... Currently having hydraulic issues with my M95. When I activate any lever the system doesn't hold steady pressure. The steering feels sluggish, and I have no power going uphills. Already checked the quick connects, everything thing seems ok, fluid level is good, not foamy or aerated. Any suggestions/info would be greatly appreciated. Thanks in advance!
   / Kubota M95 Hydraulic issues #2
For the Hydraulic problem do you have a pressure gauge to check system pressure? If not, you should consider one as it will tell a lot about what is happening. Also has the filter been changed lately? If not I would start there. A common problem also is trash holding a relief valve open. Sometimes even a damaged O-ring on the relief can create a similar issue.
As far as losing power uphill I would think that is unrelated to the hydraulic issues. What happens when you lose power? RPM drops?
Hope this helps some and welcome to TBN!
   / Kubota M95 Hydraulic issues #3
Your tractor has 2 x hydraulic pumps, it "appears" ALL hydraulics are affected, as noted previously, filters would my first port of call, and suction line to pump, and possibly pump drive gear or spline.
   / Kubota M95 Hydraulic issues #4
assume you have hyd shuttle? is it engaging fully in forward/ reverse? not sure this is your problem, but i've had to adj the hyd shuttle cable tension in the past. on one occasion had to replace a sticking hyd shuttle cable, but this may not be your problem. just a thought
2001 International 3800 4X2 School Bus (A50860)
2001 International...
AUCTION STARTS HERE @ 9AM (A51242)
AUCTION STARTS...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2013 FREIGHTLINER CASCADIA (A50854)
2013 FREIGHTLINER...
Apache 8800E Gasoline Generator (A50860)
Apache 8800E...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
