Kubota M59 block heater install
   / Kubota M59 block heater install #1
caballero59
Buena Vista, CO
Kubota L39, M59, ZD326, Deere 6415
Went to the dealer today to pick it up and noticed the installation sheet said the hydraulic pump needs to be removed. This is nearly a no-go for me. Is is possible to work it in to the freeze plug hole without removing the pump?
   / Kubota M59 block heater install #2
Absolutely not. The pump has to come off and even then it is a tight squeeze, where you will be lucky to get good access to it.
   / Kubota M59 block heater install #3
Unless your north of the arctic circle, The right battery, 30-50% kerosene mix, some good anti gel additive, and 5W-40 synthetic diesel formulation oil seems a lot easier.
I hear you loud and clear. It's not so much about getting it started but pampering it a little bit when its zero.
   / Kubota M59 block heater install #5
Don't go with the block heater - a PITA to instal. Use a radiator hose tank heater - easy to instal, provides good heat & circulation.
   / Kubota M59 block heater install #6
Wise advice. A recirculating lower rad hose heater does a wonderful job and sure beats the aggravation of the block heater. Life's too short and lots of things that can go wrong. Even better is mike69440's advice to use synthetic oil for easy starting. Kubotas can take it, no problem.
   / Kubota M59 block heater install #7
Those kits for a lower hose heater are only around $100 or less. I saw 0-40W diesel oil. Was surprised!
   / Kubota M59 block heater install #8
When we lived in a cold climate I used 0W40 or maybe it was 5W40 and started a 90HP Kubota at 20 below. Yes, it was in a barn but that's cold and it cranked not much different from summer. Fired right up, chugged for a moment and I let it warm up for an hour. Transmission was still cold. Lots of advantages to the newer synthetic oils.
   / Kubota M59 block heater install #9
0-40w would not really help getting things turning at winter temps.
0W-40 on the other hand would be thin as 0 weight at 0 degrees C and still be 40 weight at 100C. A much better combination for winter work.
   / Kubota M59 block heater install #10
I have a dealer installed block heater on my L4240 and on occasion use it. I've never had a problem starting the tractor without it but it does help. Often I just don't want to wait for it to heat up enough to make a difference. I doubt I would go through the work of removing the hydraulic pump to install one.
2017 TRAILSTAR END DUMP TRAILER (A50854)
2017 TRAILSTAR END...
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
Payment Terms (MUST READ) (A50774)
Payment Terms...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
One pallet of tree stands (A50860)
One pallet of tree...
JOHN DEERE 5205 TRACTOR (A51406)
JOHN DEERE 5205...
