3-Point Hitch Kubota M105X 3 point lift problem
   / Kubota M105X 3 point lift problem #1
Ecapt3
Bagwell,Tx
Kubota M105X
I can not get my 3 point lift to work from inside the cab of my Kubota M105X. I will work from outside controls on the rear tire fender. I have a dash light with the lift arm display that is flashing constantly. I have checked the wires from the arm rest control to the floor and seemed to all good.
Any ideas on how to fix the problem?
   / Kubota M105X 3 point lift problem #2
I know very little about electronically controlled 3 pt hitches but I'd guess a loose wire or faulty inside control switch or faulty relay.
   / Kubota M105X 3 point lift problem #3
You could have several problems. Let's hope it is simple.
1. The ECU can get confused. If you shut the unit off with the 3 point in one positions (let's say "up') and some one either A. moves the sliding lever (on the armrest I think) that that controls lift arm height, or B. lets the arms down while the tractor is not running (or the leak down, neither situations happen often), the the ECU senses the 3 point arms in one location, but sees the lever in another and flashes the light (and stops the lever from working). Same thing can happen if you have the key "on" (no running engine) and you move the lever. Basically, get the 3 point all the way to the bottom, set the lever all the way to the bottom, shut the tractor off and restart it and see if that helps. Also, check to make sure the knob that sets your "upper travel limit" of the 3 point arms is tuned to the "max" setting. If the arms are left up and this knob gets turned while the engine of off, it can confuse the ECU (the arms are above the upper limit and the ECU does not know what to do).
2. Bad wiring or ECU. The cab controls go through the ECU before going to the 3 point solenoids. The buttons on the back give straight battery voltage to the solenoid. The buttons on the back will work no matter what is wrong with the ECU or cab wiring (as long as the tractor will run).
These explanations are a little over simplified, but the principles are sound.
2015 CHEVROLET CAPRICE POLICE CAR (A51222)
2015 CHEVROLET...
2000 PETERBILT 357 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2007 Volvo VNL Truck Tractor (A51039)
2007 Volvo VNL...
2023 PJ 49FT Gooseneck Trailer - 35+5, Mega Ramps, 30,000 GVW, Electric Brakes (A51039)
2023 PJ 49FT...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
