I have a [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] LX3310 and recently I had an issue. I have a heavy duty flail mower and I am clearing some brush. In using the bucket to push down the brush and then drive over it and use the mower to chop it up. Everything was going fine and as expected as I was opening a new trail. But then I lost the use of my hydraulics to raise and lower the bucket. When I got back in the field I noticed that the lower hose was disconnected from the tractor to the FEL. Took a while to figure out what needed to be bled out to release the pressure to get it hooked back up. Then about 30 minutes later, the same problem but noticed that a large piece of brush was the reason for this disconnect as it had bumped the hose connector perfectly and disconnected it.
Is there a guard that is out there for this sized tractor that would prevent the brush from coming up and doing any damage to the hydraulic hoses and connectors? My dealer was about useless and said that I need a new coupler even though I explained the brush and that I have used the loader since with no issues. I believe if it were a coupler issue that pressure would cause it to disconnect while in use.
Thank you for any suggestions or wisdom.
God Bless,
Jake
God Bless,
Jake
