Kubota L6060 power loss - SCV issue?
   / Kubota L6060 power loss - SCV issue? #1
jk96
Elite Member
Missouri
Kubota L6060
Kubota L6060. In high gear rabbit I noticed a loss of power coming up a slight grade that should not have bogged down. Today same thing then started running fine then threw a P0093 code. (Fuel system leak or loss of fuel pressure).
When this happens RPMs drop from 2500 to around 1800-2000. Engine continues to run smooth, no misfire, no hesitation, no smoke. Fuel filter replaced and water seperator screen cleaned last fall about 50 hours ago.
Plugging details into Chat GPT I'm getting advice that the fuel suction control valve is likely acting up? Any other insights as to other possible causes? It only happens when the engine is working hard to maintain speed, other than that runs and idles fine. Don't notice it in lower ranges where the wheels are turning easier. Just wondering if Chat is leading me down the right path.
Jeremy
   / Kubota L6060 power loss - SCV issue? #2
My guess would be the fuel filter needs to be replaced again. I have 2 L6060's and have had similar issues.
I'll start there since it's easy and cheap but given only 50 hours on the filter I have my doubts on it. Especially being intermittent.
   / Kubota L6060 power loss - SCV issue? #4
I have had lots of issues with the fuel system on my L6060's.
One time there was trash blocking the inlet to the water separator. Once there was trash in the tank keeping fuel from leaving the tank.
Once there was trash in a check valve which is between the water separator and the main fuel pump.
Once, I had to change the entire fuel system because of water in the fuel causing rust. That job cost me $10,000.
I've also had to change the fuel filter before I expected to need to change it.
Let us know what you end up doing.
Will do. Going to start with the filter today and check seperator.
Miller Millermatic 25 Welder, SKU# 907321, S/N MJ260223N, Rated Output-Amperage 200 (A59076)
Miller Millermatic...
2019 Ford Explorer AWD SUV (A56859)
2019 Ford Explorer...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2007 34ft. Homemade Pipe Trailer (A55973)
2007 34ft...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
