3-Point Hitch Kubota L48 TLB - cheaper alternatives to factory 3-point hitch
   / Kubota L48 TLB - cheaper alternatives to factory 3-point hitch #1
jgoodma1
Raleigh, NC
Kubota L4060
I have a 2004 Kubota L48 backhoe that I bought used. The backhoe is removable. The machine did not come with the 3-point hitch components. I'm a total rookie tractor mechanic. I want to start using some rear 3-point hitch implements and am trying to figure out a cheaper way to put together a 3-point hitch than having to buy the factory version, which now costs around $1400 for the full setup. I have not been able to find any after-market versions for my machine anywhere. I guess there just are not enough L48's out there to make it worthwhile for someone to make a knock-off. And from what I have read online, the L48 seems to have 3-point hitch components that are unique to it.
I have the diagram for the full 3-point linkage/drawbar/hitch setup and it seems to me that the only really critical factory-supplied parts might be the lift arms. The rest of the components look like they could come from Agri-Supply or Tractor Supply, with maybe some simple modifications where the lifting rods connect to the lift arms. So maybe I have to spring for the expensive lift arms...... but can get away with generic lifting rods, top link, etc. Is that realistic or am I missing something important?
   / Kubota L48 TLB - cheaper alternatives to factory 3-point hitch #2
Agrisupply also sells the heim joints so you can weld up your own lift arms. I have purchased them and the vertical lifting links plus stabilizer chains from them in the past. All very reasonable.
I would use at least 1" thick steel, and you can prob pay a weldor if you don't DIY.
   / Kubota L48 TLB - cheaper alternatives to factory 3-point hitch #3
Keep in mind most of the Kubota connections will be metric thread.
2016 GENIE S-65 TELESCOPIC BOOM LIFT (A52709)
2016 GENIE S-65...
1685 (A58375)
1685 (A58375)
EXCAVATOR RIPPER (A58216)
EXCAVATOR RIPPER...
New/Unused SD Lanch SDLE20 Mini Excavator (A57453)
New/Unused SD...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
Willmar 4550 Wrangler Articulating Loader (A56438)
Willmar 4550...
