Kubota L4150 low power at loader and 3 pt
   / Kubota L4150 low power at loader and 3 pt #1
mweller
Kubota L4150
I have a mid 80s Kubota L4150 that has very little power at the 3pt and loader. Prior to me working on this it had gotten a new pump, hydro oil and filter. I made an adapter to bolt on the pump to check flow and pressure directly off of the pump, and I have good readings off of the pump (10gpm at 2500psi). Then I hooked my gauge up to the bottom port of the priority flow valve, which feeds the loader and 3pt, and I only get 5gpm at no load, and if I try to apply a load the flow and pressure drop to just about zero, then pressure slowly builds but tops out around 1600psi. According to the service manual I should replace the priority flow valve plug (cartridge), but I have talked to a couple Kubota dealers and they say they have never had one go bad, plus the plug is not available separately, only as a complete priority valve assy. So before I shell out $636 for a new one, does anyone have any suggestions or thoughts on this? The top port of the priority valve feeds the hydraulic shuttle drive, which works fine. I haven't taken it apart to check it, but the clutch locks tight when engaged and releases when disengaged.
UNUSED 48 in. Oversized Bolt Cutters (A50860)
UNUSED 48 in...
Headache Rack (A50860)
2025 K2215 UNUSED Portable Restroom (A50860)
2025 K2215 UNUSED...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A49461)
2008 24ft...
1999 Ford F-800 Vacuum Truck (A50860)
1999 Ford F-800...
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
