Kubota L245DT Hydrolic lift/ three point problem
   / Kubota L245DT Hydrolic lift/ three point problem #1
Jjpbe
Yanmar 1510D / Kubota L245/ Toro 223D
Hi,
I am owning a Kubota L245DT which works well. I only have a problem with the hydrolic lift/ three point . It’s not lifting very high. It should lift much higher. What could be the problem? I have checked the hydrolic/transmission oil but that seems ok. Any ideas?
many thanks.
jjp
   / Kubota L245DT Hydrolic lift/ three point problem #3
Do you have a stop on the control lever? Have you moved it? Many tractors have an adjustable upper and/or lower limit point on the control. You could start by checking for that.
2016 KENWORTH T660 SLEEPER (A50854)
2016 KENWORTH T660...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
Target Ecoline Walk behind concrete saw (A49461)
Target Ecoline...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
Caterpillar 730 Articulated Dump Truck (A49346)
Caterpillar 730...
