Kubota L175
   / Kubota L175 #1
airbear
Pineville
L175
My very old L175 is having an oil pressure problem. It will start oil light goes out it will run for a moment, then the oil light comes on, idle or reved up, the lite stays on????? I think that if it were the pump, the light would not go out. I wonder if a port is stopped up and for a moment the pump pressures up and when runs out of oil and the light comes on. shut it down and start it back up, light goes out for a moment then comes back on...... any ideas????? thanks
   / Kubota L175 #2
I think I would replace the oil filter, make sure oil level is good, fit a pressure gauge to see what the oil pressure really is and if still a problem, drop the oil pan to look at the oil pick up screen and tube. Easy job-just had my L225 oil pan off due to a plugged oil screen. Cleaned and all is well.
Could also just be a weak oil pressure switch.
David
   / Kubota L175
David
Good tip , many thanks
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2007 JOHN DEERE 310SJ BACKHOE (A50458)
2007 JOHN DEERE...
2006 International 4400 LP Crew Cab Heavy Haul Truck Tractor (A49461)
2006 International...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
