Kubota L1500 Compact Tractor - FULLY REBUILT and Upgraded
Item Details
Type
Make
Kubota
Selling my fully rebuilt Kubota L1500 2WD compact diesel tractor. The L1500 has 8 forward gears and 2 reverse via a high/low range selector. It also has 4 gears for the PTO. The 3 point hitch comes with a draw bar and CAT 1 top link. This little tractor is perfect when coupled with a finish mower or box blade!
The rebuild includes but isn't limited to transmission seals/bearings and new reverse gear, new clutch, new main oil seal, new 3pt piston seals, new engine filters, new front tires, and a ton more. Also the engine was rebuilt with new pistons, rings and rods about 50 hours ago. Basically anything and everything needing replacement or in questionable condition was repaired or replaced to include a TON of nuts and bolts. It was then sandblasted and painted. Along with the rebuild, I replaced the old generator/regulator setup with a modern alternator, added oil pressure and coolant temp gauges, added a fuse block and broke out the circuits, added an optima battery and battery disconnect switch. This rebuild was a labor of love and no expense was spared. She fires right up and runs great.
Along with it comes a complete parts tractor that could theoretically be rebuilt as well but needs new sleeves and pistons. The parts tractor picture only shows the rolling chassis but I do have the rest of the engine parts, body work and a set of ag rice tires.
This is a solid little tractor that I hate to see go but with our recent move just don't have the space that it deserves. This is a must see. If the listing is up, it's available. Local pickup only with cash in hand. Asking $4250 but can entertain reasonable offers, no trades. It'll need a big trailer to get both tractors and all the spare parts. Located in Ocean Springs, MS.
