Kubota keeps stalling out
   / Kubota keeps stalling out #1
WarrenPFJr
Catskills, NY
Kubota B3200
Hey all,
I’m hoping someone might be able to offer some insight on why my kubota keeps stalling out. It’s an ‘09, B3200 with exactly 1200 hours on it. I can not seem to keep it running, it just stalls and will not idle. Air filter has been replaced. Fuel filter has been cleaned and there is fuel in it. Any thoughts? Does this sound like an injector nozzle problem? Or fuel pump maybe?
I would appreciate any insight.
   / Kubota keeps stalling out #3
Start by confirming fuel flow from the tank connection out. Disconnect lines to confirm flow.
Some other possibilities are bad fuel (water or bacteria), bad lift pump, bad fuel stop solenoid, sucking air from cracked fuel lines.
The fuel filter I see listed for your machine is not cleanable, and should be replaced. What did the filter look like? Did you bleed the air out of the fuel system after opening it up?
I wound up taking the fuel filter out and swished it around in a clean jar of diesel then blew air on it. Only because I didn’t have a clean one on hand. There were some larger particles of debris on the outside of the filter and a few small pieces of dirt resting in the bottom of the filter container. I put it back in and started things up. It would run for about 30 seconds or so then die (what the manual said to do anyway to bleed the air). I did this 5-6 times. Then decided to take a look at the injectors. I blew out each of the 4 supply lines. While trying to get the return loop off of one of the injectors I snapped it. The nut spun the whole injector assembly and snapped the line. This pretty much happened with all 4 injectors. So I will be looking for a new return line tomorrow. Should I replace the injectors too while I’m in there?
I’ll be replacing the fuel filter as well. Fingers crossed this is my issue.
   / Kubota keeps stalling out #6
I would try cheaper options first. Can some body tell OP the price of injectors?
Check the fuel tank for crud , flush out if posssible. Also blow out the tank to filter line as well.
From your description it is a partiale blockage.
   / Kubota keeps stalling out #7
Is there vent slightly plug?
I did run it with the fuel cap off thinking there may have ben a vent issue. It didn’t seem to help
   / Kubota keeps stalling out #9
Its a fuel problem, like everyone says and save the $$$ on new injectors.
Start at the tank clean it out completely, then the fuel line to the filter, I would even replace it if pieces of black rubber come out of it.
Then install a new filter, then the hose to the injector pump should be removed and inspected for the same deuteriation.
When all thats done, put in FRESH diesel fuel and bleed the system, hopefully that cures it. :)
This is the cheapest fix, then move unto your injector pump, ect.... If the problem still exists.
2019 Allmand Light tower (A49461)
2019 Allmand Light...
1999 Ford F-800 Vacuum Truck (A50860)
1999 Ford F-800...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
UNUSED Clear Corrugated Polycarbonate Roof Panels (A50860)
UNUSED Clear...
1986 ASPT 30ft S/A Pole Trailer (A49346)
1986 ASPT 30ft S/A...
