Kubota G5200 cutting deck pulley question.
   / Kubota G5200 cutting deck pulley question. #1
Yanmar186d
Melbourne Australia
Yanmar 186D
Does anyone know how to undo the nut on the pulleys? I'm finding it hard to hold the pulley and try and break the nut free? Any thing I'm missing here?
Thanks for any help.
   / Kubota G5200 cutting deck pulley question. #2
Impact gun.
Use a strap belt on pulley.
   / Kubota G5200 cutting deck pulley question. #3
If it is a blade drive pulley, use a short 2x4 to block the blade rotation. That will secure and hold the pulley from moving.
   / Kubota G5200 cutting deck pulley question. #4
^ That's exactly what I would do.
I have tried putting the block of wood under the blade but the blade spins.
   / Kubota G5200 cutting deck pulley question. #6
Try putting the block so that it gets jammed between the tip of the blade and the side of the deck.
Aaron Z
I have wedged the blade but the shaft spins on the blade is what I meant to say.
Got them off tonight with a cordless impact gun, thanks for the advise guys.
New Holland TS6. 120 Tractor (A50322)
New Holland TS6...
Auger with Extension (A50860)
Auger with...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
TANNKO  130BBL VAC TRAILER (A50854)
TANNKO 130BBL VAC...
2009 PETERBILT 388 TANDEM AXLE DAY CAB (A51219)
2009 PETERBILT 388...
1982 TANDEM AXLE CEMENT MIXING TRAILER (A50854)
1982 TANDEM AXLE...
