Kubota Bagger
   / Kubota Bagger #1
JimBinMI
Veteran Member
Coldwater, Michigan
2014 Kubota BX25D-1, 2014 Kubota BX1870
I have a BX1870 with a 54” deck. I found a used GCK60-23BX BAGGER WITH A 60” boot kit. I did a little adaptation and made the boot and the orange wedge that goes under the front right of the deck work. Admittedly I never follow the rule of only cutting a third of the grass height. I’m now experiencing some clogging issues in the boot.
Anyone have any ideas…or does anyone have a 54” boot kit that wants to trade for a 60”.
To buy a new 54” boot kit is 💰💰!
Thanks!
   / Kubota Bagger #2
Slowing down in heavy grass should work.
   / Kubota Bagger #3
I have a bagger for my BX. I found the brackets for the boot were not properly aligned, and it caused enough obstruction to impact the flow. I even re-coped the boot to sit completely on the deck. Now I have minimal issues. I did buy quick release clamps, so when I go have a clog, it’s an easy and quick removal of the discharge hose to clean it out.
   / Kubota Bagger #4
I’ve had a bagger on my BX for 10 years! Ain’t not never clogged it! Do you have the wedge shaped piece that fits into/onto the underside of the deck?
2014 John Deere 6125R Utility Tractor with loader (A50657)
2014 John Deere...
2005 PETERBILT 357 TRI AXLE DUMP TRUCK (A51222)
2005 PETERBILT 357...
2008 Ford Crown Victoria Sedan (A48082)
2008 Ford Crown...
20 ft. Shipping Container (A50860)
20 ft. Shipping...
T/A Gooseneck Dump Trailer (A50860)
T/A Gooseneck Dump...
3-Point Disc Plow (A50860)
3-Point Disc Plow...
