Kubota B7610 Engine Starts But Drive and Hydraulics Not Operable
   / Kubota B7610 Engine Starts But Drive and Hydraulics Not Operable #1
pjmsj21
Eugene
Kubota B7610
My wife was using our B7610 with our brush cutter when she found that the tractor would not move forward or backward and none of the hydraulics would work. I can easily start the engine but can't lower or raise the front loader, lift the brush cutter or get any movement either forward or backward. I for the life of me cant figure this out.....can you steer me in the right direction?
   / Kubota B7610 Engine Starts But Drive and Hydraulics Not Operable #2
Is the range selector in neutral?
   / Kubota B7610 Engine Starts But Drive and Hydraulics Not Operable #3
Sounds as though the Ujoint (if it has them) off the engine broke. Had this happen on my JD 4010. No hydraulics would work because no power goes to the HST unit.
Ralph
The range selector is in the low gear and you can move it from low to neutral to high....so unfortunately that's not it.
2022 Club Car...
2009 PETERBILT 388 TANDEM AXLE DAY CAB (A51219)
2009 PETERBILT 388...
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
2022 Club Car...
2020 KUBOTA RTV...
2001 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2001 Big Tex 10PI...
