Kubota B7510 (hst) Transmission noise
   / Kubota B7510 (hst) Transmission noise #1
ed glenn
kubota B7510
I have a 7510 that had the same noise as described on your forum. Transmission noise under no load. Noise leaves when tractor is pulling. The fix is very simple. The dust cover surrounding the drive line going to the front axle has a nylon bushing in the end next to the transmission. The bushing gets dry and galls from lack of grease. Replace rear half of dust cover or bore an eight inch hole and make sure hole goes through nylon bushing. Take a grease gun that you use on the nose of a chain saw bar and grease through hole. Seal with silicon. I would reccomend you grease the bushing every twelve months or when the noise starts again.
HAPPY TRACTORING!!!!!!!!!!
   / Kubota B7510 (hst) Transmission noise #2
Welcome to TBN. :)
   / Kubota B7510 (hst) Transmission noise #3
Welcome to TBN!!! Happy tractoring to you too!!! :)
   / Kubota B7510 (hst) Transmission noise #4
Hello, I have moved your post to the Kubota Owning/Operating Forum. You will have better luck finding assistance there. ;)
Thanks for joining TractorByNet.com!!!
2014 Kinze 1100T Dual Auger Grain Cart (A50657)
2014 Kinze 1100T...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
1997 Mercedes Convertible (A48082)
1997 Mercedes...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
HEADACHE RACK (A50854)
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
