Kubota B6100 hydraulics
   / Kubota B6100 hydraulics #1
DaveDitchfield
I have aadded a snow blade to the front of my b6100 and would appreciate any advice on hooking up the hydraulics. The original controls for a blower in the front were tapped into the distribution block on the right side beside the motor. This arrangement seemed to create a bypass problem for the 3 point hitch controls. I understadn that I can modify the distribution block to solve this problem.
I would appreciate any advice. Thanks
Thanks for this. I'm in Kingston, Ontario. Any other tips are appreciated!
   / Kubota B6100 hydraulics #4
Looks like there are a few of us on here with B6100's .
I adapted ATV snowplow to the front of mine. As crazy as that sounds, it fits rather well, and works great. I didn't measure it, but I believe it is a 4' blade. I used this setup, not only because it was readily available to me, and was in-expensive, but it has a manual lift, so I didn't have to bother with hydraulics, and if I remove 2 pins and one 1/4" bolt, I can back up and leave it there. It's heavy enough for the plowing I plan on doing.
Thanks for all the help. The blade is up and running and the hydraulics work like a charm
   / Kubota B6100 hydraulics #6
Good to hear to hear that. I was wondering. Do you use chains? or do u have filled tires?
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
1268 (A50490)
1268 (A50490)
2015 International DuraStar 4300 Street Sweeper Truck (A50323)
2015 International...
John Deere 270 Wheeled Skid Steer (A50322)
John Deere 270...
PICKUP TIRE CHAINS (A50854)
PICKUP TIRE CHAINS...
2013 John Deere 824K (A51039)
2013 John Deere...
