Kubota B6100 front pto advice needed 18mm 22 spline
   / Kubota B6100 front pto advice needed 18mm 22 spline #1
smokinhart
Manhattan, Kansas
B6100DT Kubota
I have a B6100 I need to attach a hydrualic pump to the front PTO which is connected to the crankshaft via a shaft/crank pulley adapter.
Looking for correct part number shaft/crank pulley adapter/electric PTO. These parts ARE supposed to be available from Kubota as I am told but no one can answer the shaft size question so far.
70090-00104; CLUTCH ASSY
66704-88530 1 FLANGE, PTO ( Front PTO)
66704-88540 1 SHAFT, PTO (Front PTO)
Just bought and received a 9310 shaft assembly for my 6100 off ebay from a fellow member here. It looks like the B9310 I purchased is a larger spline diameter. This unit I bought has the hub assembly bearing, the electric clutch and a 27 mm by 22 spline shaft sleeve. My 6100 needed a 18 mm instead of the 27 mm. Wish I had the micrometer earlier.
Anybody know what the 27 mm fits? IS the 66704-88540 1 SHAFT, PTO (Front PTO) the smaller 18mm size? Help appreciated at TBN
Pull Type Garden Wagon (A50860)
Pull Type Garden...
Non running toro mower (A48082)
Non running toro...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2013 CAT 950K WHEEL LOADER (A50854)
2013 CAT 950K...
2006 International 4400 LP Ambulance (A50323)
2006 International...
Root Rake (A48083)
Root Rake (A48083)
