Kubota B6100 Dynamo
   / Kubota B6100 Dynamo #11
On the matter of the horn and lights: A Dynamo is just another type of generator to produce electric current. The voltage will vary with the load. If you severely overload any type of generator then the voltage will start to drop. The more severe the overload is, the deeper the voltage drop will be. A battery that has bad cells can short out internally, and I have even seen batteries that are allowed to discharge so deeply that the polarity will reverse in a single cell of in the entire battery. That can sometimes cause the battery to explode, but it would definitely present a heavy overload to your generator. Now another principal also comes into play... Electricity always follows the path of least resistance. If you battery has an internally shorted cell, or a polarity reversal, then it is going to be the absolute least resistance anywhere in the system. As long as that load is there you won't get enough extra electricity to operate the coil in a horn or to light the filament in a bulb because it's all flowing through the battery.
   / Kubota B6100 Dynamo #12
G'day Matt the tests are the same as an alternator you basically want to hook a multi meter up to the battery and check to see what sort of voltage you have got anything over 12.5v with the engine at about 1200rpm is good, seeing it is a generator it is not often that you see alot of charge under this eng speed. Best of luck with it:)
Jon
   / Kubota B6100 Dynamo #14
No they are different, a dynamo has rotating magnets inside a fixed winding and puts out ac, an alternator has a rotating field that is inside the winding(s) with ac output rectified internally and a generator has a fixed field winding with rotating windings inside that make dc current transfered through the brushes.
David Kb7uns
   / Kubota B6100 Dynamo #16
G'day good explanation Dave but a generator/ dynamo actually puts out DC not AC and this is why for their size they don't have as greater output as an alternator. OOOPS sorry i just read the end again and realised you did put dc and not ac my apologies
Jon
2018 CATERPILLAR 308E2 CR EXCAVATOR (A50458)
2018 CATERPILLAR...
PETTIBONE B66 EXTENDO (A51222)
PETTIBONE B66...
CHALLENGER MT465E TRACTOR (A51406)
CHALLENGER MT465E...
2015 FREIGHTLINER  CASCADIA (INOPERABLE) (A50854)
2015 FREIGHTLINER...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
Set of AG R4 Wheels and Tires (A51039)
Set of AG R4...
