Kubota B5100
   / Kubota B5100 #1
mikeeg
North East-New Jersey
Cub Cadet 1050
Still checking out a low hrs B5100 and was wondering if anyone out there has used one with small bush hog rotary cutter and if the machine has the power. I will be maintaning about 3 acres of woods and small meadow area. I would like to put as small as possible a cutter on this so I can get thru the wooded area. Hoping it will do the job.!!!
   / Kubota B5100 #2
Mikeeg
I have a little B5100 and a 38-inch rotary cutter for it. The rotary cutter does a good job on weeds, brush, and small saplings. I also mow about 4 acres with my 48” finish mower. You can take care of 3 acres with it if you not in a big hurry.
rsislo
   / Kubota B5100
The B5100 has a Wood's 48" finish mower with it that I will be able to cut the other acre of lawn with and possible use my Cub Cadet 1020 for only blowing snow. Main use for the 5100 would be to keep the woods down.
If you have a few pictures of your 5100 please post as I have not seen many 5100's out there. Thank You
   / Kubota B5100 #4
Picture? Of that old thing. Sure I have a few but they will need to be resized. I need to head to work so I don’t have time to resize the picture. I will try and get it resized and posted late 10/13/05.
I do use my rotary mower to create new and maintain trails in my woods.
rsislo
   / Kubota B5100 #6
Here is a photo of my B5100 with the little rotary cutter.
rsislo
   / Kubota B5100
Thanx for the pic I belive this little machine will work for my needs, now it's time to deal.
2005 International Pier Drilling Truck (A49461)
2005 International...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2014 Dodge Grand Caravan SXT Van (A48082)
2014 Dodge Grand...
1999 Ford F-800 Vacuum Truck (A50860)
1999 Ford F-800...
2025 KG45 UNUSED U-Type Screw Pin Shackle Set (A50860)
2025 KG45 UNUSED...
2025 K1220 UNUSED Single Garage Metal Shed (A50860)
2025 K1220 UNUSED...
