Kubota B4200 rear PTO modification for a tiller
   / Kubota B4200 rear PTO modification for a tiller #1
Edmundo
Roberts Creek, BC, Canada
Kubota B4200 / 1988
Hello Folks,
I have just purchased a 1988 Kubota B4200 to replace a 1978 Turf Trac with a tiller and mower etc. I am selling the Turf Trac without the tiller as I want to use it with the Kubota. The Kubota has a six spline 1 3/8" x 2 1/2"male PTO shaft offering power at the rear. The tiller has a 3/4" x 3/4" female drive shaft. Any ideas how I can join the two?
Also, the Kubota's PTO driveshaft has a plastic sleeve on it which appears fixed and seems to prevent its use. I do know that the PTO has never been used and wonder if this is some kind of protective cover. The plastic is pretty heavy. Do you know what purpose this serves?
Any comments will be most appreciated. Thanks! Edmund
   / Kubota B4200 rear PTO modification for a tiller #2
Edmundo,
Splt the existing drive shaft. look at a new shaft that has the standard spline and see if the new spine end wioll for in the old tiller end of the shaft... Then make sure you have the proper lenght.
Regards,
Chris
Thanks Chris,
I now want to retain the existing setup for the Turf Trac so that it can also run the tiller as well. Therefore I am looking for a setup to adapt it to the Kubota.
Cheers, Edmund
I am now onto a supplier of PTO parts and think we can jam something together. Thanks for your help!
   / Kubota B4200 rear PTO modification for a tiller #5
Did the Turn Trac have a 540RPM PTO? Many of the Bolens, Cub, etc PTO machines had 2000-3600 RPM PTOs.
Aaron Z
   / Kubota B4200 rear PTO modification for a tiller #6
Edmundo,
I'm looking in the tractor supply catalog and there seems to be several adaptors... So maybe you'll get lucky....
Regards,
Chris
2-3k sounds like I could whip cream with that tiller! I'll check it out anyhow. Thanks. E
   / Kubota B4200 rear PTO modification for a tiller #8
   / Kubota B4200 rear PTO modification for a tiller #9
It is just like you said, a protective cover. It is a thick hard rubber. It should slide off, if not, a razor blade should cut through it so you can remove it.
Brian
   / Kubota B4200 rear PTO modification for a tiller #10
Hello Folks,
The cover on the PTO unscrews... It just keeps the dirt off the spline...
2025 K0608 UNUSED 3-Rail Style Fence Panels (A50860)
2025 K0608 UNUSED...
1997 John Deere 920 MoCo Mower-Conditioner (A50860)
1997 John Deere...
New Holland B95 Backhoe (A50490)
New Holland B95...
Pallet Forks - Clamp On Attachment (A50860)
Pallet Forks -...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
1999 Ford F-550 Bucket Truck (A50860)
1999 Ford F-550...
