Kubota B20 w/ Hoe Hydro Issues
   / Kubota B20 w/ Hoe Hydro Issues #1
jwiseguys
Holley,Oregon
851 powermaster kubota B20
I broke a fitting on the B20 and have noticed that the H fluid will overflow out the back at times and appears foamy, I replaced the H filter and drained the system before repacing with proper Kubota fluid from Taking a Napa.Filled to proper level etc. Ran it today for 1 hour and it was fine. Next time if I use the Hoe it might not swing left to right, that is the indacator that it has puked out some fluid. Did I miss something?
any ideas..........
jwiseguy
   / Kubota B20 w/ Hoe Hydro Issues #2
have you repaired you're leak, and has it acted like that since it ran fine
   / Kubota B20 w/ Hoe Hydro Issues #3
if the answer is yes is it only the swing circuit you lose
   / Kubota B20 w/ Hoe Hydro Issues #4
His reservoir is probably to full and maybe there is an suction leak somewhere.
   / Kubota B20 w/ Hoe Hydro Issues #5
Does the B20 have a diverter lever/valve that you switch when changing from the backhoe to the 3pt hitch? My B21 and L39 do so I was wondering if it is fully engaging. That could cause the backhoe to run strange. The foamy hydraulic fluid would indicate air getting in the system to me.
MarkV
I have checked the level and it is fine. No Diverter either. No Leak as I can think of. Ran the FEL Saturday with no signs of slowing or lack of lift. Guess I will keep lookin as I use it. weather has been an omen lately, but the days are gettin longer. Like to get it right before I start spankin on the salmon in the Big River might need it to lift the cooler!
Johnny
   / Kubota B20 w/ Hoe Hydro Issues #7
Check your relief pressure and that will tell you about the condition of the pump and or the hyd circuit. If they are at specs, then you should be doing OK
JJ
Will look into it when I can, Iwill be busy thisweekend with easter and all.
I have a pdf file manual that I will look at for specs.
Thanks, Johnny
RoGator 844 sprayer (A50490)
RoGator 844...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2001 International 3800 4X2 School Bus (A50860)
2001 International...
2008 Nissan Rogue SUV (A50860)
2008 Nissan Rogue...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2015 VOLVO VNL SINGLE AXLE DAY CAB (A51222)
2015 VOLVO VNL...
