Comparison kubota 161 or Takuechi 145
   / kubota 161 or Takuechi 145 #1
BTS44
Help me! Which is better? Takuechi 145 or Kubota 161??
   / kubota 161 or Takuechi 145 #2
I think you have picked the two leaders there - our local hire shop does Kubota - but says the only reason they do not do Takeuchi is that the local dealer is also a rival in hire industry.
Just to confuse - do not forget Kubota's zero-tailswing U50.
I guess in your shoes I would look at quality of dealership as an important consideration.
I might also look at upgrade plans - I am not sure the Takeuchi may be due for a new model soon as the 135 seems to be upgraded to a 235 although the 125 and 145 are still current. Just a thought.
Edit: Just seen that there is now the TB250 - http://www.takeuchi-mfg.co.uk/NewTB250.htm - but that may mean the TB145 will be cheaper!!!!
J
   / kubota 161 or Takuechi 145 #3
I've not seen a single TakEuchi dealership but many kubota
I have no experience with either macHines but if i were to purchase an excavator I'd go with the one that I can most readily Available parts and support
Joel
Yes I know the Kubota is a zero turn, but why wouldnt every one buy a zero turn they cost the same?
Are there any disadvantages with the zero swing?
   / kubota 161 or Takuechi 145 #5
Sometimes zero tail swing is achieved, in part, by widening the tracks making a ZTS digger less manoeverable.
Also, on principals of leverage - there are two things to achieve a counter-balance for the boom - one is to put a weight further from the centre (fulcrum) such as on a non-ZTS digger - the other is to put heavier weight nearer the centre such as on a ZTS.
So a ZTS digger may be wider and heavier than a non-ZTS of same capability.
J
Thank you for the info. So if I will be digging in tight areas the weight is a trade of for the zero turn. They will dig about the same?
Sorry if its a dumb question
   / kubota 161 or Takuechi 145 #7
There is a newer version of the KX161 that just came out, its a K050. There is also a zero tail swing model thats the U55. We just got our first ones two weeks ago.
2018 Ford F-150 Pickup Truck (A56858)
2018 Ford F-150...
2025 GPS Trailer (A56857)
2025 GPS Trailer...
CFG Industry H15R Mini Excavator (A57149)
CFG Industry H15R...
2245 (A58376)
2245 (A58376)
LOT: (50) 14 Oz. Tubes of Star Fire Multi-Purpose EP 2 Grease (A59076)
LOT: (50) 14 Oz...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
