Kohler Command in the LT 1046
   / Kohler Command in the LT 1046 #11
</font><font color="blue" class="small">( I see the cheaper JD LT's are using entry level Briggs Intek engines rather than the Kohler Courage, I wonder if JD is just letting the other manufacturers test the water with the Courage line?
)</font>
Even a Courage is likely more expensive than the Briggs Intek, and the Kohler is probably a better engine. The higher end JD's use Kawasaki engines but Kaw doesn't have a low cost line as far as I know. That might explain why the low end tractors don't use them too.
   / Kohler Command in the LT 1046 #12
)</font>
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
2014 Chevrolet Cruze Sedan (A53424)
2014 Chevrolet...
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
2019 RAM 2500 Crew Cab Pickup Truck (A53422)
2019 RAM 2500 Crew...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
2010 Ford Transit Connect Cargo Van (A53422)
2010 Ford Transit...
