Kioti LB1914 Hyd Pump Question
   / Kioti LB1914 Hyd Pump Question #1
RMS
I have an LB1914 with 280 hours with a Kioti front loader. Tractor is probably 4-5 years old (guess). They hydraulics are non exisitant at idle. The respond well at anything above 1800 RPM. I have checked the relief valves to verify that they are not stuck open. Do they make a larger Hydraulic pump for these tractors? I use an amazing amount of fuel just getting the rpms to run the loader/three point.
   / Kioti LB1914 Hyd Pump Question #2
Did you check and make sure the deverter valve is open all the way?
I have moved the diverter valve. In one position I get no hydraulic action no matter the engine RPM. In the other, I get hydraulic action at higher RPMs. I should clarify, if I have the tractor idling and raise the three point or hold the bucket controls they will start moving after 20-30 seconds. The movement is hardly noticable. The power steering works just fine under any conditions.
I have removed the relief valves and found no broken springs or trash in the seats, nothing notably out of order. I have also checked the hydraulic fluid and cleaned the filter.
   / Kioti LB1914 Hyd Pump Question #4
My LB 1914 will move the loader at idle, very slowly but immediately. Same with 3ph.
   / Kioti LB1914 Hyd Pump Question #5
The LB1914 will just barely move the loader until you increase the rpm's.
Did you just receive this machine or have you had it for a while and it just started to work like this?
   / Kioti LB1914 Hyd Pump Question #6
Does the hyd pump make a lot of noise at low rpm, If making noise it could be sucking air. check all the fitting and tighten the hose clamps.
I've had the tractor a little less than a year. It has always acted like this. I am third owner I believe. I"m not sure it has been taken car of all that great, but it is low hours. It is also in the hard to start cold catagory, but I've not known many diesels that are not. The ring gear and starter gears are all tore up. Got the new parts, but need to get them on. The pump makes no noise whatsoever. I've had a dealer tell me that the new 1914's have larger pumps than the older ones. The owners manual shows it having a 6gpm, but I'm not sure if that is actually what is on the tractor. The pump looks original. How big of a pump does a new 1914 have? 10GPM? I would buy a new pump, even a used pump if it was a larger pump that would not overload the relief valves. If there is a larger pump available, how much larger is it?
Thanks for the replies!!
   / Kioti LB1914 Hyd Pump Question #8
I 'm putting a bigger pump (10gpm)on my 3054. The price has gone up almost double. It's around 500 bucks. I'm not sure if that would be the same for yours though.
Serial Number is 504000231
2015 Ford Explorer AWD SUV (A48082)
2015 Ford Explorer...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
UNUSED Brown Metal Roof Wall Panels (A50860)
UNUSED Brown Metal...
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
AMCO F42B-3626CS 13ft Pull-Behind Wheel Offset Harrow Tiller (A49461)
AMCO F42B-3626CS...
Diesel Fuel Tank with Pump (A50860)
Diesel Fuel Tank...
