Kioti lb1914 electrical problem
   / Kioti lb1914 electrical problem
No. You haven't provided enough information. What you described in your first post could be considered normal. We don't know the tractor or whether it has a generator, alternator or even a regulator. Some alternators have the regulator built in.
The alternator is a fixed magnet type and must have a rectifier in it because I get a DC voltage reading directly from it. The tractor also has a voltage regulator with a 6 prong connection.
   / Kioti lb1914 electrical problem #12
Check the output voltage at the alternator for comparison. if they match, no worries. If the alt output is higher than what you read at battery terminals there is a voltage drop, meaning probably a corroded connection between them. If you are not experiencing any issues with other electrical loads( lights,etc) then I wouldn't be at all concerned. JMHO
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
1982 LeeBoy Motor Grader (A51039)
1982 LeeBoy Motor...
2014 Ford F550 4x4 Bucket Truck with Versalift SST40 - 45FT Working Height (A51039)
2014 Ford F550 4x4...
24 Foot Wells Cargo Enclosed Trailer (A50324)
24 Foot Wells...
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
